1989 Chevy Truck engine losing power
VROMAN11
  • 1989 CHEVROLET TRUCK
  • V8
  • 60,000 MILES
My question is about a winnebago rv on a p30 chevy chassis, 1989 with 454 engine and carburater.
The rv will run great. It starts easy and has lots of power. After driving it for 50 +/- miles it will just start to die as if it was not getting enough fuel. You can pump on the gas pedal and it will still just die. I wait for a while and it will start fine, but a while later it does the same thing again. We have done the following: -changed the fuel filters under chassis and in carburater
-changed the fuel pump on the engine
-taken off the fuel tank and voila, another fuel pump in the tank. It was all burned out from "maybe overheating"? We changed that. It still does'nt work! Is there a relay for that pump &/or does it even need that pump? Help. Any other ideas? (This is the short version of all of the things we have tried but we feel it is lack of furl related.)
Thanks
Friday, August 6th, 2010 AT 2:07 PM
2CARPRO JACK
  • 11,533 POSTS
Without the wiring diagram for your RV I couldnt say if there is a relay for the fuel pump, but there most likely is. Try following the wiring harness that goes to the tank unit to see where it goes, then you may find the relay. It is normal for it to run out of fuel if there is apump inline that you are trying to draw through but it isnt running. They are just flow/volume restrictions at this point, which will do what you describe
Friday, August 6th, 2010 AT 6:55 PM
