I took a sheet of paper and stuck down under the 2 ports turned the key on and both sides sprayed out fuel, So now I have fuel
Just because fuel came out you need to check it with a pressure gauge EFI system don't like low fuel pressure it has to be within specs to function correctly
Tuesday, May 5th, 2009 AT 9:10 PM
