1988 Chevy Truck 4 wheel drive-A/C, heat
RUDY910
  • 1988 CHEVROLET TRUCK
  • V8
  • 4WD
  • 150,000 MILES
When u shift 2 4wheeldrive it blows the fuse for a/c, heat
Friday, November 27th, 2009 AT 9:23 AM
DR LOOT
  • 2,311 POSTS
You got me, I have never heard of that problem, are you sure your diagnosis is correct?
Friday, November 27th, 2009 AT 5:46 PM
RUDY910
Yea im sure my diagnosis is correct. It always blows the fuse and the 4wd dont work when that happens
Sunday, November 29th, 2009 AT 12:23 PM
DR LOOT
  • 2,311 POSTS
I am sorry you are correct, I was checking the wiring diagram on your truck, the AC/Heater fuse is connected to the trans-case, it get its power Supply from the speedo fuse, my question now is, dose your speedometer work? If it does. Most likely it is this which in the transfer case, that is grounded in other words, it is no good. Because every time you put the transfer case in 4 Wheel Drive. The fuse blows.
Sunday, November 29th, 2009 AT 12:57 PM
RUDY910
Yea my speed ohmeter works. We finally figured it out. Thanks for the help
Sunday, November 29th, 2009 AT 1:35 PM
HILDY43
How did yopu fix it I have this prob now!
Monday, January 24th, 2011 AT 1:43 AM
DR LOOT
  • 2,311 POSTS
Replaced (VSS) on the back upper side of transfer case, make sure you wiring harness is not damaged. Let me know if you need anything else.
Monday, January 24th, 2011 AT 2:32 AM
HILDY43
What is a vss? When I unpluge the indicator light from under the truck my heat works fine but I dont think I have 4x4 yet?
Monday, January 24th, 2011 AT 3:16 AM
HILDY43
My truck is also a 5 speed.
Monday, January 24th, 2011 AT 3:17 AM
DR LOOT
  • 2,311 POSTS
5 speed manual?
Monday, January 24th, 2011 AT 3:45 AM
HILDY43
Monday, January 24th, 2011 AT 3:54 AM
DR LOOT
  • 2,311 POSTS
Let me restudy the situation and I will get back to you, anything else you want to tell me go-ahead
Monday, January 24th, 2011 AT 5:27 AM
