1987 Chevy Truck 1987 scottsdale wont start
FLY1256
  • 1987 CHEVROLET TRUCK
1987 Chevy Truck V8 Four Wheel Drive Automatic
my truck was at idle and in park then it started to idle down and now wont start but it will turn over and has plenty of juce
Friday, July 30th, 2010 AT 1:15 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Friday, July 30th, 2010 AT 4:50 PM
