Electrical problem
1976 Chevy Truck V8 Four Wheel Drive Manual 0
All the lights work on this truck. All the gauges work fine. However, once I turn the headlights on, the gauges peg to the left and the turn signals don't work. What are the steps to diagnosing the bad ground? There are lots of wires to check with a meter. Also, could a bad headlight switch cause this issue? I replaced the headlight switch and this problem started. Thanks in advance.
Sep 28, 2009 at 2:33 PM
