1971 Chevy C10 pickup, 307ci
GTOJACK
How does one get the door panel off. there are two screws behind the woodgrain panel. Does the woodgrain panel come off by itself by unsnaping it? I have the door handle and window crank off and the scwews on the bottom out. I wound think that the panel would just lift up and off, but these two screws up top? Any ideas.
gtojack
Mar 21, 2007 at 6:29 PM
MIKE H R
  • 3,094 POSTS
the door panel has retaining clips, it holding it in place, start at the bottom and use a flat screwdriver and gently pry the bottom corners to get the retaining clips to pop out.
Mar 22, 2007 at 1:06 AM
