1967 Chevy Truck Coil spring install
C-TEN
Suspension problem
1967 Chevy Truck V8 Two Wheel Drive Manual 225k miles
Hello, Is there a way to change the coil springs without disassembling the front end? Thanks.
Jul 15, 2009 at 6:41 AM
DR LOOT
  • 2,311 POSTS
the answer to your question is negative, you will have to remove the coil spring's all tools are available for rental at your local parts store, I remember my 67 Chevy pickup, they used to break the U-Bolts all the time on the front lower control arms, make sure you replace those if you're going to change the coil springs.
Jul 25, 2009 at 8:28 AM
