1966 Chevy Truck Ignition
1966 CHEVROLET TRUCK
130,000 MILES • 6 CYL • 2WD • MANUAL
DSEIP
HI, I've recently purchased the old beast and did a little work to it. New platinum plugs, new accel 8mm wires. New cap and rotor. I replaced the points with a Pertronix module. The coil was replaced with a Pertronix Flame thrower coil. After all was done I started the engine. Seems to run fine until I put a load on it. Then it starts to lose powerand misfire, even backfiring through the carb.
I removed the coil on the advice of a friend and the engine runs better and smoother. He believes the coil was just too much for the stock cap causing it to arc.
I would like to add the coil back to improve the engine performance. What can I do?
May 26, 2008 at 6:55 PM
MASTERTECHTIM
  • 4,750 POSTS
you must use a resister or ballast with the coil or a internal resister coil. with the petronics installation instructions it tells you which one you need. the coil runs on 9 volts, thats why you need the bassast or resister wire. double check the instructions and get back to us if you need further help
May 26, 2008 at 11:18 PM
