1965 Chevy Truck fuel
WALTLORE
Engine Performance problem
1965 Chevy Truck 6 cyl Two Wheel Drive Manual
truck will run fine ,then shutsdown after 10 minutes, already replaced fuelpump,coil ,flushed gas tank out,cleaned sending unit,took carb off and cleaned,new lines and filters,still wants to shut itself off???????
Oct 14, 2010 at 3:03 PM
  • 75,988 POSTS
Hi waltlore, Welcome to 2carpros and TY for the donation
Is this a contact point distributor or an HEI ignition ??
Oct 14, 2010 at 3:09 PM
JDL
  • 16,098 POSTS
When it stalls, does it restart immediately? If not, have a helper crank it while you visually check for spark at the plugs. You can keep a know good spark plug or spark tester in the glove-box, won't get hot. Then you just pull a plug wire, use tester. If you have spark everywhere, I'd have to check fuel. With a rockchester carb, I can pull the airhorn off without removing the carb, check for gas in the float bowl. A clogged exhaust could cause problems, is there a butterfly valve on the exhaust?
Oct 14, 2010 at 3:11 PM
