2006 Chevy Trailblazer CHECK ENGINE LIGHT
SHARPER82
  • 2006 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 57,000 MILES
THE CODE SAYS MY THROTTLE BODY NEEDS TO BE CLEANED I CLEANED IT BUT THE LIGHT IS STILL ON
Tuesday, December 22nd, 2009 AT 1:28 PM
What is the actual P-code?
Tuesday, December 22nd, 2009 AT 1:31 PM
SHARPER82
PO506
Tuesday, December 22nd, 2009 AT 4:08 PM
A P0506 DTC trouble code may be caused by one or more of the following:
A vacuum leak
An air restriction in the intake air path or exhuast
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Internal engine problem
Failed PCM
Possible SolutionsThis DTC is more of an informational code, so if there are any other codes set, diagnose them first. If there are no other codes, inspect for vacuum leaks, restrictions, and damage. If there are no symptoms other than the DTC itself, just clear the code and see whether it returns.
Tuesday, December 22nd, 2009 AT 4:58 PM
