2006 Chevrolet Trailblazer CD Won't Eject
WRMAHER
I have an OEM 6 disc CD changer in dash and I cannot get any of the six discs to eject. I have a sinking feeling that one of the discs has an adhesive label attached to it. Aside from taking it to the dealer, is there anything I can do to get the discs ejected and get the CD player working again?
Feb 15, 2007 at 6:50 AM
BRUCE HUNT
  • 3,754 POSTS
Hard to tell from here but if you can reproduce the growling noise by taking off the motor and running in cool conditions off the vehicle that might be a method. If it works fine then replace the pump. What are the codes you get when there is a fault?
Dec 13, 2006 at 3:49 AM
2CARPRO JACK
  • 11,533 POSTS
Aside from removing and disassemblong, it I cant think of how else to get your discs back.
Feb 17, 2007 at 11:31 PM
Suggested Repair
Remove the in-dash 6-disc changer and disassemble it to retrieve the stuck discs, or have a dealer or audio shop do that work. Do not force ejection if a labeled disc may be jammed.
Conversation Summary
The owner of a 2006 Chevrolet Trailblazer cannot eject any discs from the OEM in-dash 6-disc changer and suspects a disc with an adhesive label is stuck. One reply discussed an unrelated pump and motor issue. The relevant advice is that, aside from a dealer visit, removing and disassembling the changer is the way to recover the discs.
