Have them change the fluid and filter in the transmission, trans will get loose is a bunch of hooey.
Then have them fill rear axle with 90 weight oil, grease fittings should be 2 behind rear wheel, then comes a tune up, always change the air filter with the oil every 3000 miles if you dont have the owners manual then get a repair manual from the auto parts store it will give you a maintance schedule and if you do not work on the blazer it will help you with what needs to be done with that knowledge the mechanic cant rip you off with unnessary work.
SPONSORED LINKS
Friday, October 15th, 2010 AT 9:27 AM
