2002 Chevy Trailblazer Engine replacement
DGIGGLES1
  • 23 POSTS
Engine Mechanical problem
2002 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic
I am wondering if this type of engine can be pulled from the top. I can't seem to get back to the bolts on the bell housing, any suggestions??
May 11, 2009 at 5:58 AM
BRIAN 1
  • 1,030 POSTS
you have to remove the trans support and lower the rear of the trans down to get the bellhousing bolts,yes you can pull these from the top but you have to remove the headlights,the radiator,the front grill and radiator support housing and the engine comes out through the front.I've done afew and they SUCK to do.
May 11, 2009 at 7:43 AM
