Can the idle control valve make the vehicle act like the transmission is slipping?
2002 CHEVROLET TRAILBLAZER
170,000 MILES • 6 CYL • AWD • AUTOMATIC
JMASTERJEDI22
I describe the problem to you guys earlier about when I turn on my air-conditioner the RPMs of the vehicle go up-and-down up-and-down until it eventually dies. You guys told me it could be the idle control valve or a vacuum line. Well now the problem is getting worse and I was wondering if the idle control valve could also make the vehicle act like the transmission is slipping?
Sep 12, 2014 at 1:44 PM
HMAC300
  • 48,601 POSTS
poor engine running can effect the way a trns works. try cleaning throttle plate on both sides and iac hole with choke cleaner then check fuel pressure with a gauge 60-66 psi key on engine off autoparts rent it.
Sep 12, 2014 at 10:45 PM
