P0601 trouble code means that a serial communication failed inside the computer at least 6 times.
Symptoms
Likely, no symptoms will be discernible to the driver, other than the illuminated Check Engine Light. Typically the engine runs fine, gauges work, etc
With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed (I recommend you take it to a dealership for this). The good news is it *may* be covered under your emmissions warranty. So even if you're out of bumper-to-bumper warranty or powertrain warranty, check your warranty guide or dealer to see if this is covered.
SPONSORED LINKS
Sunday, November 29th, 2009 AT 4:28 PM
