Well the first thing you can do in that case is check the battery.
Does any of the accessories turn on? Headlights or anything? If not change the battery and check for loose and coroded fittings
if those turn on but as soon as the key is turned to start or on then the power goes then I belive you have a bad ignition switch.
SPONSORED LINKS
Friday, December 14th, 2007 AT 4:16 PM
