1997 Chevy Suburban car won't start
NICKI6190
  • 1997 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 4WD
  • 200,000 MILES
I've just replaced my starter, but now my engine will turn over, but it won't start. Also, after it rains my car doesn't start until it is dry outside.
Sunday, January 24th, 2010 AT 4:43 PM
Rain or shine don't wait for nothing do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Sunday, January 24th, 2010 AT 5:24 PM
Related Engine Not Running Content
How to fix an engine that wont start
VIDEO
