1996 Chevrolet Blazer Cuts Out Over 45 MPH
GLEWING
  • 5 POSTS
I have a 1996 Blazer 4x4 4.3 with 180,000 miles Just put in about 700.00 in ball joints shockes and getting alined and balanced. Also new radiator, theromstat and clutch fan. Now I'm having problems with once i get up to 45mph or higher, it feels like I got bad gas. I put some injector cleaner in it about a week ago. And still doing it, it comes and goes, but the farther I drive it and more it acts up like its cutting in and out with the rmp's jumping back and forth. I had someone hook up their computer but found nothing. I do know that even since I bought the thing if the gas get below 1/4 tank I hear this noise coming from underneath there the fuel tank is. Please any help would be helpful. I drive it everyday with my kids and need it get it fixed ASAP!! Thanks!
Apr 2, 2007 at 3:17 PM
  • 75,988 POSTS
Check the fuel pressure and inspect the fuel filter-could be a bad gas and also a clogged-up fuel pump sock in the tank
Apr 2, 2007 at 4:19 PM
GLEWING
  • 5 POSTS
thanks I'll try that today! :)
Apr 2, 2007 at 4:25 PM
GLEWING
  • 5 POSTS
Problems solved Thank You so much for the quick reply!! Come to find out it wasnt anything major. I had someone put in a new radiator for me and the hose for the transmission line had came off!! So I checked it and it had no fluid in it. I put some in it so it would get me home and drove GREAT. Having someone else put a new clip on it to hold it in.. THanks again for the quick reply!!! :D
Apr 3, 2007 at 2:58 PM
Suggested Repair
Reconnect and clip the transmission cooler hose that came off during the radiator job, then refill the transmission fluid. If cutting out continues, check fuel pressure, the fuel filter, and the in-tank pump sock.
Conversation Summary
A 1996 Chevrolet Blazer 4.3 cut in and out above about 45 mph, with RPM jumping, and made a noise near the tank below a quarter tank. An expert suggested checking fuel pressure, the fuel filter, bad fuel, and a clogged fuel-pump sock. The owner later found a transmission cooler hose had come off after a radiator replacement and the transmission had no fluid. Refilling the fluid restored normal driving, and the hose was to be secured with a new clip.
