1989 Chevrolet S-10 Blazer Hard Cold Start
TRUCKERJOHN
i have a 4.3 engine that ran good, but all of a sudden when its cold it is hard to start, the inside of the rotor is black with carbon and it will start if you dont touch the gas but you cant step on it untill it warms up, i replaced the the cap and rotor and the dist module,spark module, computor,ect, i recently replaced the fuel tank and pump so now im going to check for fuel presure, any ideas?
Feb 26, 2006 at 3:08 AM
JPAM
  • 307 POSTS
did you also check or change Spark plugs and wires.. If rotor was that bad id check../ This 2 items are cheaper than starting on fuel system.. Whats the milage on this vechile... thnks
??? Over the road or local driver???
Feb 26, 2006 at 5:03 AM
MVANNESSJR
  • 223 POSTS
Check the injectors, make sure they aren't clogged. Check the fuel pressure as well.
Feb 26, 2006 at 6:06 AM
Suggested Repair
Check and replace the spark plugs and plug wires if worn, then verify fuel pressure and inspect the fuel injectors for clogging.
Conversation Summary
The owner of a 1989 Chevrolet S-10 Blazer 4x4 with a 4.3 engine reported a sudden hard cold start. The rotor was black with carbon, and the engine would start only if the throttle was not touched, then would not accept throttle until warm. The cap, rotor, distributor module, spark module, computer, and coolant temperature sensor had been replaced, and the fuel tank and pump were recently replaced. Experts advised checking the spark plugs and wires before more fuel-system work, and also checking fuel pressure and whether the injectors are clogged.
