2000 Chevy Tracker Window adjustment
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
DCFINNELL
How do you adjust the driver side window? The Haines manual says to adjust the regulator but I don't see any adjustment, only three screws.
Apr 14, 2010 at 3:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Observe the cleats on the bottom of the glass, which are attached to a pin on the regulator, and a metal clip slips into the cleat and holds the pin in place. There are two holes the pin can fit in, but the wrong hole will make the glass not run parallel. Remove the metal clip on the cleat that holds the pin in place and change the hole the pin is in.
Remove the glass by disconnecting the bolts attaching it to the regulator and sliding it up and out of the door. Check to see how tight the screws mounting the regulator are. Tighten the screws if needed.
Slide the window glass back into the door and the regulator. Make sure the glass goes in straight and lube both sides of the glass tracks with lithium grease so the glass will slide freely.
Operate the window controls and make sure the window comes up and down easily and on track. Replace the door panel and all other components.
Apr 22, 2010 at 3:37 PM
