2002 Chevy Tahoe oil overfill
105,000 MILES • V8 • 2WD • AUTOMATIC
KIMRM9
I have used Mobil 1 oil since 15,000 miles, quickie lube place changed my oil then put in 6 quarts of their oil and 6 quarts of my Mobile 1 all 5w30.
I then drove the car 100 miles before I found out, and then 100 miles back to the dealer where they removed 12 quarts of oil and put in a new filter and 6 quarts of Mobil 1.
Tha car seems normal , oil pressure is normal, and there are no evidence of oil leaks.
What should I expect?
Jan 12, 2009 at 9:07 AM
JAMES W.
  • 2,394 POSTS
12 quarts, I didn't think they could get an engine to hold that much. Anyway, if you didn't blow an engine seal by now, you should be ok. This is why I change my own oil. I got tired of going in for a $14.95 special, and coming out with an $80.00 bill.
Jan 12, 2009 at 9:40 AM
  • 75,988 POSTS
If there's no knocking noise such as thumping and thudding -you're good to go-then again time will tell.
Quick lube didn't catch the extra 6qts when checking the oil level-stop going there.
Jan 12, 2009 at 9:43 AM
