2001 Chevy Tahoe VACCUM LEAK
200,000 MILES • V8 • 4WD • AUTOMATIC
SKRAAG
i was told i have a vaccum leak.how can i fix this i do not know where the leaks are coming from.the engine was hooked up to a computer and they said i have two vaccum leaks.i can not go over 50mph
Feb 21, 2008 at 11:10 AM
BMRFIXIT
  • 19,053 POSTS
Some vacuum leaks are easy to do and as simple as replacing a vacuum hose
and others are very difficult to find
check intake manifold
my question is do you know where is your vacuum leak
Feb 21, 2008 at 11:18 AM
SKRAAG
[quote:f22bd9628f="skraag"]Engine Performance problem
2001 Chevy Tahoe V8 Four Wheel Drive Automatic 200000 miles
i was told i have a vaccum leak.how can i fix this i do not know where the leaks are coming from.the engine was hooked up to a computer and they said i have two vaccum leaks.i can not go over 50mph[/quote:f22bd9628f]
Feb 22, 2008 at 3:38 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d4802dc694="skraag"][quote:d4802dc694="skraag"]Engine Performance problem
i was told i have a vaccum leak.how can i fix this i do not know where the leaks are coming from.the engine was hooked up to a computer and they said i have two vaccum leaks.i can not go over 50mph[/quote:d4802dc694][/quote:d4802dc694]
what is the codes ?
check mass air flow sensor
Feb 22, 2008 at 10:44 AM
