Vacuum leak causing lean codes
250,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
922HONDA
Changed intake manifold gaskets code still came back. any idea?
Jun 16, 2017 at 8:47 AM
  • 31,937 POSTS
two ways of locating a vacuum leak, spray some brake clean carefully around the inlet and vacuum hoses if the leak is bad the engine will surge. the best method is a smoke machine, this pressurizes the induction with harmless smoke and you can see where the leaks are, many work shops have this equipment.
Jun 16, 2017 at 5:20 PM
