2000 Chevy Tahoe Window does not go up
127,000 MILES • V8 • 2WD • AUTOMATIC
RBLONDIN
The left rear window goes down but only returns up about 3 inches and stops. Motor seems strong untill it stops. Cable seems to move freely until it stops tight (does not seem to be slipping). Does it sound like I need to lubricate the track? Where would you lube (Limited access)? Or does it sound like the whole system needs to be replaced? Dealer says to expect $500+ for repair. I need to find a cheaper solution (DIY?).
Oct 27, 2008 at 7:35 AM
MASTERTECHTIM
  • 4,750 POSTS
most likely the window regulator needs replacement. a independent repair shop should be able to do the job for about half the cost of dealer. the cable binds on the rollers and there is no way of repairing.
Oct 27, 2008 at 11:39 AM
