2000 Chevy Tahoe not starting
GREGCHALKER
  • 2000 CHEVROLET TAHOE
When my tahoe starts it runs great but most days it will not run in the mornings. It will fire and go dead. I can try again it will fire right up again and go dead. In the afternoons it will crank and keep running and not skip a beat. I have changed my cap and rotor and fuel filter. I have it narrowed down to a fuel problem because I can spray starter fluid and it will run. I have good fuel pressure and fuel to the intake manifold. I have no idea what it could be from there. It has been doing this about 4 weeks now. It does not signal the computer with a problem.I have had that checked.
Saturday, August 1st, 2009 AT 9:56 PM
  • 109,723 POSTS
Have you actually checked fuel pressure? Here is a how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
ALso, you may want to check for an injector pulse using a noid light to determine if the injectors are firing.
Tuesday, May 4th, 2021 AT 12:02 PM
