2000 Chevy Tahoe Drivers side rear wiew mirror remove/repla
2000 CHEVROLET TAHOE
75,000 MILES • V8 • 2WD • AUTOMATIC
MESACAPRI
Instructions please on replacing or reinstalling the drivers side rear wiew mirror 2000 Tahoe
Feb 14, 2010 at 6:47 AM
KHLOW2008
  • 41,814 POSTS
Hi mesacapri,
Thank you for the donation.
Here are the procedures.
Removal & Installation
Remove upper trim panel extension by unclipping panel from door.
Disconnect power mirror harness connector.
Remove power mirror mounting nuts.
Remove power mirror assembly.
To install, reverse removal procedure.
Tighten power mirror mounting nuts to 80 INCH lbs. (9 N.m).
© 2008 Mitchell Repair Information Co., LLC.
Feb 14, 2010 at 9:40 PM
MESACAPRI
My problem is removing the mirror only -- not the entire assembly
Feb 16, 2010 at 11:57 PM
KHLOW2008
  • 41,814 POSTS
Sorry for the delay in replying. seems the notification process fouled up again.
1. To remove mirror back and glass assembly from housing, insert fingers as far as possible behind mirror back (toward center) and pull straight out with enough force to disengage snap-fits from adjuster mechanism.
2. To install, align mirror back snap-fit hooks with adjuster mechanism ramps. Gently press
mirror back toward adjuster mechanism until engagement of snap-hooks.
3. Check mirror operation with foam placed below mirror to catch glass if it should fall.
Installation is successful if mirror back stays firmly attached to motor pack.
Feb 18, 2010 at 5:01 AM
