1999 Chevy Tahoe low pressure and knocking
TACHRIS79
  • 1999 CHEVROLET TAHOE
Engine Mechanical problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic 133k miles
pressure is low accept for driving over 20 mph but engine is constantly knocking.
Saturday, June 6th, 2009 AT 12:47 PM
PEAR69
  • 1,482 POSTS
If by low pressure you mean low OIL pressure, your oil pump seems to be failing. The knocking you hear can be a few things, if it is a ROD knock - you should consider rebuilding the engine. If it is a LIFTER knock then you can replace the lifter. Solve the OIL pressure problem first.
Sunday, June 7th, 2009 AT 10:20 PM
