1998 Chevy Tahoe Tahoe WON'T ALWAYS START
BOB SKIBBE
  • 1998 CHEVROLET TAHOE
  • V8
  • 4WD
  • 20,500 MILES
I BOUGHT THIS TAHOE AND HAVE TAKEN EXCELLANT CARE OF IT. 3,000 MILE OIL CHANGES AND ALL THE OTHER REQUIRED MAINTANCE.
IN THE LAST TWO MONTHS WHEN I TRY TO START IT, IT CRANKS GREAT BUT THE ENGINE WILL NOT START ALWAYS.
IT MAY NOT DO THIS FOR 20 TO 50 START UPS BUT THEN IT WILL AND I'M AFRAID TO TRAVEL AS I LIVE IN A RURAL ARKANSAS.
I TURN THE KEY ON AND WAIT ABOUT 5 SECONDS BEFORE CRANKING WITHOUT PUTTING MY FOOT ON THE ACCELERATOR.
WHEN THIS STARTED MY MECHANIC GAVE THE TAHOE A COMPLETE TUNE UP AND CHECKED THE FUEL PUMP. HE TOLD ME THE PUMP WAS PUMPING 60PSI BUT THAT THE FUEL INJECTORS WERE DIRTY AND I NEEDED TO GO TO A GM DEALER FOR THIS.
I DID AND HAD THEM CLEANED PLUS THEY SAID I NEEDED THE RIGHT BANK CATALAYIC CONVERTER REPLACED WHICH I DID ALSO.
NONE OF THIS HELPED THE PROBLEM. THE GM DEALER SAID IT STILL MAY BE A FUEL PUMP PROBLEM AND I WAS VERY LUCKY TO NOT HAVE HAD TO REPLACE A PUMP SOONER. I HAD THEM PUT A NEW FUEL PUMP IN AND I STILL HAVE THIS PROBLEM WITH THE TAHOE NOT ALWAYS STARTING. I HAD AN IGNITER REPLACED 3 YEARS AGO. PLEASE FEEL FREE TO CALL ME AT 870-405-5500 THANK YOU, BOB SKIBBE
bobskibbe@suddenlink. Net
Thursday, December 4th, 2008 AT 11:01 AM
RHALL77
  • 3,361 POSTS
A couple of things to check. Do you know if they replaced the fuel filter when they did the tune up. Also do you know if they checked the fuel pressure regulator. These will cause a hard start. Let me know and I will see what I can do to help you
Thursday, December 4th, 2008 AT 5:36 PM
BOB SKIBBE
Yes the fuel filter was replaced and the fuel regulator was checked.
I forgot to tell you that at 176,000 miles I had a fuel pump module and sending unit, theft deterent system ignition lock cycilnder and fuel pressure regulator installed while on vacation 3 years ago at a Chey dealer that I forgot about. This out of state dealer told me that 1998 Tahoes had starting problems.
The tahoe has been at my mechanic for a week and can't locate whats wrong.
Can I get any help directly from GM?
Thank you, Bob Skibbe
Saturday, December 13th, 2008 AT 10:15 AM
RHALL77
  • 3,361 POSTS
Yes they can help you if you take it to your local gm dealer
Monday, December 15th, 2008 AT 4:56 PM
