When I turn the key to the "on" position I can hear the fuel flowing from the tank & when I depress the small stem inside the fuel pressure Schrader valve the fuel squirts up. Checked the distributor cap it was mostly clean & had no cracks. All wires seem to be in good shape.
Also on a side note my fuel gague is not working properly. It gives a false reading of "E" even when there's gas in the tank & it fluctuates when I accelerate and brake. This problem is secondary to me I want to get it running first then handle this problem unless their connected.
SPONSORED LINKS
Tuesday, October 13th, 2009 AT 2:19 PM
