1997 Chevy Tahoe
TODD DOVE
  • 1997 CHEVROLET TAHOE
Engine Mechanical problem
1997 Chevy Tahoe V8 Four Wheel Drive Automatic
I have a rough running engine and im getting a trouble code of p300 which is a multiple misfire code but I have a distributor, plugs, and wires that were replaced within the last 6 months.
Wednesday, January 14th, 2009 AT 10:08 AM
PEAR69
  • 1,482 POSTS
What brand of plugs - wires did you use? If the timing was not checked and set by a dealers' computer then the timing is probably off. A timing light will NOT set or check the timing on these engines. The timing MUST be set by a tech 1 GM scann tool. And a dealer is the only one who has one. It'll cost around $50 and about one hour of your time to have this done.
BTW--if you installed anyother brand plugs -wires etc. Other than A/C Delco then you are wasting your time. GM has specificaly designed these ignitions to work on only A/C Delco parts -- Maybe that's why they are going down. Keep us posted
Saturday, January 17th, 2009 AT 5:05 PM
