HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Tahoe
Engine
Symptoms
Misfire
1997 Chevy Tahoe MISSFIRE IN CYLINDER #6
DIVINE7
MEMBER
1997 CHEVROLET TAHOE
V8
4WD
AUTOMATIC
10,753 MILES
WHAT EFFECT WILL BENT PUSHRODS HAVE ON A 5.7 ENGINE AS FAR AS PERFORMANCE.
Saturday, February 14th, 2009 AT 9:53 PM
MECHANIC
Should prompt you to check the sparkplug/compression and injector for no.6
Bent pushrod will caused the valve not to fully open less A/F mix will enter the combustion chamber
Saturday, February 14th, 2009 AT 9:57 PM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
Starts Missing And Then Will Not Start?
I Put This Engine In And It Had 117k Miles On It Now It Has 125k I Replaced Plugs Wires Cap Rotor Fuel Filter. What It Started Doing Was...
Asked by
martain1960
14 IMAGES
1997
CHEVROLET TAHOE
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
1997 Chevy Tahoe Misfire
I Was Going To Turn The Vehicle Around And It Misfired Dramatically. "I Think It Broke Either The "cat" Or The Baffle. Had Just Started The...
Asked by
pooh123
1997
CHEVROLET TAHOE
1997 Chevy Tahoe Motor Skipping
I Have Changed Intake Gaskets, Fuelinjector Assy, Timming Sensor On Distributor. Test Foung 25 Deg Off, So I Pulled Distributor Again And...
Asked by
eluck
1 ANSWER
1997
CHEVROLET TAHOE
97 Chevy Tahoe
97 Chevroloet Tahoe Flooding Bad On 2 Cylinders. Causing Smoking And Bad Skip
Asked by
nonothingboutautos
1 ANSWER
1997
CHEVROLET TAHOE
2004 Chevy Tahoe Engine Barely Running
My Tahoe Will Barely Start And When It Does It Says The Engine Is Running On Half Power. What Does This Mean?
Asked by
aandm4
5 IMAGES
2004
CHEVROLET TAHOE
VIEW MORE
How to Repair an Engine Cylinder Misfire
