1997 Chevy Tahoe
GEORGE BALSER
  • 1997 CHEVROLET TAHOE
  • V8
  • 4WD
  • 178,000 MILES
Hi I have a 97 tahoe with a rougr miss durind ideal and worsens when you put it into gear when you drive it on the road it runs great code reader says po 306 and po 507 help
Sunday, November 23rd, 2008 AT 10:10 AM
P0306 Misfire at cylinder no. 6-check the sparkplug, compression and injector on it-
Misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Sunday, November 23rd, 2008 AT 12:28 PM
