1996 Chevy Tahoe 02 sensor near front
HELLAWEAR9
Engine Performance problem
1996 Chevy Tahoe V8 Four Wheel Drive Automatic 160K miles
i have a 96 tahoe 4x4 chenck engine light was on and the codes i recieved was 1- a missfire on #5
and 2- the 02 sensor, now i the o2 sensor , a buddy of mines parted out another tahoe and had some extra 02 sensors, and it looked good so i swaped them, the 02 sensor thats the closest to the front of the truck, fired it up car ran then cut off, so i put the old 02 sensor back in, now i was geting another code, i had to change the crankshaft sensor and the camshaft sensor ( i took it the shop and had them do it, now the truck runs but it seems to loose power whenever i accelerate, it does it every now and then,
does this sound like it could be that 02 sensor
Jan 15, 2009 at 11:20 AM
PEAR69
  • 1,482 POSTS
First, take your truck to the dealer and tell the you want a crankshaft sensor relearn proceedure done. Also, have them check the timing - PROPERLY - and adjust it if needed. The timing on your engine CANNOT be checked with a timing light. It is computer controlled. Changing the crankshaft sensor requires a relearn proceedure to be done. Changing the cam sensor (sometimes) messes up the timeing.
It is impossible to tell whether an O2 sensor is bad by just looking at it. And they rarely, if ever go bad, without some sort of timing or fuel delivery issue--before hand--being the cause of failure......What are the exact codes you are getting?
Feb 27, 2021 at 1:43 AM
HELLAWEAR9
right now the the only code i'm getting is p0305 and thats the misfire, but i really dont think a misfire would cause the truck to do what it is doing,
but i think i am going to take it to the dealer
PEAR69
  • 1,482 POSTS
Well, you really didn't say what the truck is doing other than mis-firing. The front O2 sensor -(or sensors - some engines have two front and two back)- regulates the fuel/oxygen mix into the engine. If this sensor reads too much or too little oxygen in the exhaust, it adjusts the fuel intake accordingly. Usually there is a mechanical issue with the fuel injector - fuel pressure - or spark plug and/or spark plug wires.     A miss in these engines can be very difficult if not impossible to find without a computer scanner like the ones a dealer has -- these scanners are not available to the public or other than chevy mechanics...All that being said your engine still operates on the basic 3 things   air - fuel - spark. Checking the obvious and common mechanical failures like spark plugs - wires - intake leaks or vaccume line off ETC. is always the best place to start. Jumping ahead of the problem without following basic trouble shooting will result in you spending much more money than necessary -- like changing the cam and crankshaft sensors without testing them...keep me posted.
HELLAWEAR9
what the truck is doing is hard to wxplain
i'll be accelerating then it will stutter kinda real quick
and then back to normal, its like i can slowly put more pressure on the gas pedal , but if i gun it
it will stutter,
before all these problem i changed the spark plugs
and the code for the misfire went away, then it came back, next i planned on changing the wires and the
distributor cap,
i'm really not concerned about the misfire, its the other problem thats buggin me
PEAR69
  • 1,482 POSTS
Test the throttle position sensor or have tested for proper voltage rise and fall. Also, test the MAF sensor. Make sure your air filter is new.
