Oil pressure problem
BRYAN.MCBRIDE
  • CHEVROLET SUBURBAN
1999 suburban 1500: 210,000 miles
My mechanic put in new manifold gaskets because it was leaking antifreeze. When I got it back the oil pressure gauge was all the way to the right. A couple of months later the transmission went out. They rebuilt the transmission, but when they went to start it the oil pressure gauge was down to 0, no reading. I don't want to drive it with no reading on the oil pressure gauge. Any ideas as to what to do next?
Thanks for your time.
Bryan
Wednesday, March 7th, 2007 AT 12:58 PM
CHEVY22
  • 1,375 POSTS
You may have a faulty sender which is on the back of the intake, or the tech did not plug it back in, its back by the distributor, check the wiring forst
Saturday, March 10th, 2007 AT 10:17 AM
DAWALAP
Just replaced mine on a 2003 suburban. Tools needed 1 1/16" deep socket, swivel, extension and ratchet. If you are standing in front of the truck it's on top at the rear of the block. Just behind the intake and slightly to the right. I had to use a mirror to locate the part, but once you locate it, it isn't bad. Most of the work will be done by feel. Good Luck.
Tuesday, June 19th, 2007 AT 9:00 PM
