2006 Chevy Suburban oil pressure
67,000 MILES • V8 • AWD • AUTOMATIC
TONY103
my oil pressure gauge is showing max - 80. it's normally 40. i recently added qt of oil. could that cause it?
how many holes on the dipstcik have to be coverd (there is 5 all together)?
Feb 9, 2009 at 4:38 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure sending unit if not the oil pump pressure relief valve sticking close
Feb 9, 2009 at 4:46 PM
TONY103
thanks for the answer. can you tell me if i can drive the car in this condition?
Feb 10, 2009 at 1:43 AM
  • 75,988 POSTS
If there's no knocking noises coming from the engine why not-I recommend you get the oil pressure checked.
Feb 10, 2009 at 5:49 AM
