2003 Chevy Suburban
RLDINOVO7
  • 2003 CHEVROLET SUBURBAN
Engine Performance problem
2003 Chevy Suburban V8 Four Wheel Drive Automatic
on cold mornings(30degrees and lower)engine runs rough. When engine warms up runs fine. Changed plugs, wires, checked injector psi, changed fuel pump. Has codes of PO101 and PO300
Thursday, March 4th, 2010 AT 8:18 PM
HMAC300
  • 48,601 POSTS
The one code is a multiple misfire and that can be a fuel filter/vacuum leak. I would suspect vacuum leak as it goes away when warm so the computer is richening the mixture to cove r it. So check for that. The other code is a maf( mass air flow) sensor. That is in the air duct. Make sure there are no holes in the duct between the air cleaner and throttle plate.
Friday, March 5th, 2010 AT 8:13 PM
