My 99 suburban just started running rough all of a sudden. I did look at the codes and am getting a random multiple missfires. I did remove the egr valve and engine seems to run much better. When i plug the egr ports the engine stalls. I am thinking the engine was able to get more o2 with the egr valve removed through the port. I don't think the egr valve is bad but not 100% sure. Any ideas???
Also just ran engine with egr valve removed and received a o2 sensor failure bank 1 sensor 1. Is this because of no egr or is this actual problem?
Mar 23, 2010 at 1:56 AM
