1999 Chevy Suburban
1999 CHEVROLET SUBURBAN
RICHIE28
Engine Performance problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic
1999 chev. suburban cranks and cranks before starting and after running runs rough like a misfire just tuned up with all gm parts and still have the same problem
Mar 28, 2009 at 3:49 PM
BMRFIXIT
  • 19,053 POSTS
Check engine light ON
and if so best to have the codes
most local part store should be able to help you in getting the codes and or rent the tool to do so
recheck firing order and check coil too
do not over lock the fuel pressure
let me know what u have for codes
Mar 29, 2009 at 12:59 AM
RICHIE28
I have no codes
Mar 29, 2009 at 4:23 AM
BMRFIXIT
  • 19,053 POSTS
If its a misfiring than it should show up on the scanner
check for pending codes and check misfiring data to identify cylinder s
Mar 29, 2009 at 1:55 PM
