Should be 55-61 lbs with key on engine off. Sounds like you may have a weak pump. Also check the pressure regulator, yours may be blown causing the rich codes (0172, 0175) If any fuel is present in the vacuum line to reg, replace it
SPONSORED LINKS
Sunday, April 6th, 2008 AT 8:55 AM
