Code p0420 is system low Efficiency bank 1 and p0430 is system low Efficiency bank 2 There is a lot of diagnostic procedure to resolve the issues, and it is probably going to bore you, my advice to you is with 200,000 miles on your suburban I would change the oxygen sensors on Bank 1 and bank 2, oxygen sensors only are good for about 70,000 miles, you may also have a bad Catalytic converter if you have the money change it to.
SPONSORED LINKS
Saturday, May 16th, 2009 AT 3:51 PM
