1997 Chevy Suburban wont start
BIGREICE
  • 1997 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 125,000 MILES
My car will turn over but it will not start. I changed tha plug, wires, rotor, @distcap still wont start help plz.
Sunday, August 31st, 2008 AT 3:59 PM
Do below to determine if its fuel or spark related problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
Sunday, August 31st, 2008 AT 4:10 PM
