1997 Chevy Suburban Intake manifold
1997 CHEVROLET SUBURBAN
160,000 MILES • V8 • 4WD • AUTOMATIC
BEAR61
I am trying to get the intake manifold off because there is coolant leaking between the head and i/t manifold. I think i have all the electrcal, and bolts off, but it wont budge. Do I have to take off the distributer too? and how many bolts hold that i/t manifold on?
Aug 19, 2009 at 9:49 AM
DR LOOT
  • 2,311 POSTS
you will have to remove the distributor, make sure all the bolts are out of the manifold, and take a prybar you will see on cylinder one there is it a casting area where you can put a prybar and break the manifold loose, from so much heat they are usually pretty tight to get off.
Aug 20, 2009 at 3:52 PM
