1997 Chevy Suburban
DALE8803
  • 1997 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 250,000 MILES
My Surburban is getting gas and fire but will not start
Wednesday, June 9th, 2010 AT 7:24 PM
INTERNETMECHANIC
  • 700 POSTS
Did you use a gage and check fuel pressure? Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one? Engine cranking, do you have an injector pulse, use a noid lite. Did you try starter fluid in the intake to see if it will start or try? Yes, there are safety issues using starter fluid, safety is your responsibility. I usually take the air-duct loose from the throttle-body, open the throttle valve, squirt a small amount into the throttle-body. Stand back from the vehicle, have helper crank it. If something blows up, you used too much spray. I've never had any problems, some people have.
Thursday, June 10th, 2010 AT 11:01 AM
