1996 Chevy Suburban ABS light
MERYJA LEVEY
  • 1996 CHEVROLET SUBURBAN
  • V8
  • 176,800 MILES
How to reset abs light without the scan tool?
Tuesday, October 28th, 2008 AT 11:08 PM
DLOBI
  • 125 POSTS
Fixing what triped the abs light will fix it on its own. You can disconect the battery and reset it but it will be back on if the problem has not been fixed.
Saturday, March 13th, 2021 AT 11:42 AM
MMPRINCE4000
  • 8,548 POSTS
Exvellent advice by dlobi,
You would need a chassis scanner to get the code and correct the problem, the light should go out.
While most autoparts stores will scan Powertrain codes (P). ABS codes are generally "C" codes, which autoparts generally do not scan.
DLOBI
  • 125 POSTS
There was a TSB (technical service bulletin) out a while back on the GM trucks for abs problems that involved the wheel sensors. The wheel sensor could be removed, cleaned up as well as cleaning the area where the sensor was seated. Rust/junk could get in there and lift the sensor enough to get a bad reading. You could get lucky with this clean up/fix or you might need one or more of the wheel speed sensors and worse case scenerio would be the ABS computer has problems.
