1996 Chevy Suburban 1996 Chevy Suburban Cranks but does not
TIQTYPHOON
  • 1996 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 210,000 MILES
It is a sudden problem, never had a problem with it. This morning it cranks but does not start. I sprayed carb cleaner into the throat of the intake and it start right up, but if I turn off the engine it fails to start again. I have to do this over again. Once its running, it accelerates fine and idle is fine. I have an OBD scanner and no trouble codes
Thursday, April 23rd, 2009 AT 9:04 PM
Check fuel pressure if okay test the fuel pump relay and oil pressure sending unit
Thursday, April 23rd, 2009 AT 9:08 PM
TIQTYPHOON
I replaced the fuel pump relay, and having the fuel pressure test done, also a diagnostic.
Friday, April 24th, 2009 AT 1:43 PM
I replaced the fuel pump relay, and having the fuel pressure test done, also a diagnostic. So what's happening now?
What was the fuel pressure? The pressure should be 60-66psi. Are you getting injection pulses while cranking it over
Friday, April 24th, 2009 AT 4:31 PM
TIQTYPHOON
UPDATE:
Had is checked out by a pretty good auto shop. The problem was a weak fuel pump, and I saw from doing a fuel pressure test. They replaced the fuel pump and it was back to starting up, if not running better, than before.
Wednesday, April 29th, 2009 AT 6:00 AM
