Cranks over but no start
150,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
MRJAXX
  • 22 POSTS
One day fine and the next just cranks over. I checked all fuses, tried starting fluid, then I took off a plug wire and found no spark. Actually touched it without any kind of shock. any suggestions about what to check?
Regards, Todd
Jun 22, 2016 at 5:01 AM
CARADIODOC
  • 34,415 POSTS
Step one is always to read and record the diagnostic fault codes. The people at most auto parts stores will do that for you for free. If you cannot get the truck there, you will need a simple code reader to read the codes yourself.
Do you have a 5.7L or a 6.5L? The 6.5L is a diesel, and I do not think you will be looking for spark on that one!
For the 5.7L, the best suspects are the crankshaft position sensor and the camshaft position sensor. The Engine Computer needs the signals from them for spark and injector timing.
Jun 22, 2016 at 3:43 PM
MRJAXX
  • 22 POSTS
Where should I locate the positioning sensors and how do I check if they are bad. I heard to crank the engine and see if the rpm gauge moves?
Jun 22, 2016 at 6:00 PM
CARADIODOC
  • 34,415 POSTS
Easiest is to get a code reader. I use a scanner but for this it does the same thing, just costs a real lot more.
Jun 22, 2016 at 6:04 PM
MRJAXX
  • 22 POSTS
Where is the crankcase sensor located on the engine? down by the water pump area?
Jun 22, 2016 at 7:29 PM
CARADIODOC
  • 34,415 POSTS
The crankshaft position sensor is behind the vibration damper. The camshaft position sensor is inside the distributor. Those are for the 5.7L engine. If you have something else, you have to tell me which engine you have.
Jun 22, 2016 at 7:50 PM
RENEE L
  • 1,260 POSTS
Hello Mrjaxx,
Here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com. Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
https://youtu.be/YV3TRZwer8k
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jun 23, 2016 at 12:17 PM
