1995 Chevy Suburban Hesitates and lurches
CTBIRCHEM
  • 1995 CHEVROLET SUBURBAN
1995 Chevy Suburban V8 Four Wheel Drive Automatic
When I frist start up my truck if I do not lay on the gas peddle the truck will do this shutter and shut down when I get it going I will start to drive and it will lurch forward and act as if it is not geting fuel and I must pump the gas and lay on it untill it reaches above 35mph. I have replaced the fuel modual and seal for it and am not sure what else it could be. Any help would be greatly appreciated.
Sunday, July 25th, 2010 AT 2:22 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sunday, July 25th, 2010 AT 2:30 PM
