Last night while driving home my 2001 chevy 2wd 1500 surburban started hesitating & acted like it was not getting fuel - went to gas station filled up with high test added a fuel treatment - started out but hard starting & got it to start in neutral - stopped at fast food parked in open spot looked for leaks - check under hood -oil, trans, water all ok everything was fine - started fine but about 15 miles down road heard 2 thumps car died and would not restart - tried but didn't - right before it stopped car just started hesitating and pushing gas pedal did not seem to help - no engine lights came on - having it towed home but hoping for some insight into problem so I have a clue as to what might be wrong (around 2 months ago same thing happened but started right back up ran ok but had some hesitation check eng lite came on then was told got bad gas by mechanic run good gas & a cleaner had no more problems after that until now) Thanks
Nov 1, 2009 at 3:49 AM
