1995 Chevy Suburban electrical
190,000 MILES • V8 • 2WD • AUTOMATIC
T.ARMS
Hi my truck has a starting problem, It stalled on my a few days ago I tried turning the ignition and a had a clicking noise as if the alternator was no good but I had changed 2 weeks ago, it would turn but it had a sound like it was not getting any fuel to the front of the vehicle. I turned the key to see if I could hear the fuel pump was working it was not, though I recently changed the pump. I had towed, bought a new pump and proceded to change the pump but I tested the old one and it worked, so I tested the new one and it worked also. So before I put the pump in I used a tester to check voltage reading going to the wire harness of the fuel pump and it had a reading of 9 - 10 volts. I put the pump into the fuel pump back in the tank and I tried starting it again truck still has the same problem. I just want to know if I should take it to a dealer which I know will cost alot of money or take it to a good mechanic. What should I do I am not sure what else I could check.
Dec 28, 2007 at 9:55 AM
MERLIN2021
  • 17,250 POSTS
Usually a clicking noise indicates a weak battery, poor battery connections or a bad starter....Check these first, if you cant power the relays, they won't work! Let us know how you do!
Dec 28, 2007 at 10:37 AM
T.ARMS
[quote:91bcccef88="t.arms"]Electrical problem
1995 Chevy Suburban V8 Two Wheel Drive Automatic 190000 miles
Hi my truck has a starting problem, It stalled on my a few days ago I tried turning the ignition and a had a clicking noise as if the alternator was no good but I had changed 2 weeks ago, it would turn but it had a sound like it was not getting any fuel to the front of the vehicle. I turned the key to see if I could hear the fuel pump was working it was not, though I recently changed the pump. I had towed, bought a new pump and proceded to change the pump but I tested the old one and it worked, so I tested the new one and it worked also. So before I put the pump in I used a tester to check voltage reading going to the wire harness of the fuel pump and it had a reading of 9 - 10 volts. I put the pump into the fuel pump back in the tank and I tried starting it again truck still has the same problem. I just want to know if I should take it to a dealer which I know will cost alot of money or take it to a good mechanic. What should I do I am not sure what else I could check.[/quote:91bcccef88] Thanks Merlin that was the first things I checked because they all pointed to the starter, battery, and alternator but they all checked out ok, could it be the ignition switch or a short in the system.
Thanks Merlin I had not had time to do what you asked me to do. But just today I tried to go into my car and I found out the battery was dead. I hadnt left anything on could I have a short some where or was it just a bad battery. please need your advice though I am taking it to a local NAPA this week to charge or change the battery
Dec 29, 2007 at 7:09 AM
MERLIN2021
  • 17,250 POSTS
Yes it could, but did you try crossing the I and battery terminals at the starter? If it start the solinoid is no good...the other possibilty is fuse links...
Dec 29, 2007 at 10:52 AM
