1995 suburban running problems
GREGHMC
i having problems with my suburban just shuting off
going down the road its lke it is running out of gas
and it will notstart back up right away but if u let
it sit for about 10 to 15 min it will run fine for about a mile then shuts off again i replaced the fuel pump
it ran fine for about2 days and did the same thing
so i replaced the fuel pump relay switch then it ran
for a day and didit again whats next to check any help please
Feb 14, 2007 at 12:06 PM
MIKE H R
  • 3,094 POSTS
change the fuel filter and see what happens. if the filter is clogging up it cuts down the amount of fuel
getting to the engine. when it stalls the filter is leting a little amount of gaas into the engine but not enough to let it run. while sitting the gas has enough gas to let it run until it runns low again.
it also might be a pinched or restricted line somewher, doing the same thing
Feb 16, 2007 at 10:09 AM
GREGHMC
no when it shuts off the fuel pump is not running
Feb 18, 2007 at 3:35 AM
MIKE H R
  • 3,094 POSTS
have someone turn on the ignition, but not start car. you should hear a brief whirlling sound coming
from the gas tank. if you do not check fuses. how is your oil pressure? note: while running if the oil pressure drops below specified pressure while running the oil pressure switch will act as a fuel pressure cut off device. check and see if you have juice to the fuel pump.
Feb 18, 2007 at 7:34 AM
